It is currently Sat Jun 20, 2026 2:24 am
 Post subject: Voltage Regulator??
PostPosted: Sun Jan 28, 2007 9:22 pm
Alright I have a 75 duster and I need a little help with the wiring. What hasn't been burnt out or chewed up has been cut out. So I need a little help on how to wire up the voltage regulator. I'm using an msd 6al box and the headlights/taillights were pretty simple this is the last bit of wiring I have to do and I should be able to get her running shortly. I found this website:
http://www.mymopar.com/charging.htm
I just wanted to make sure it was just this easy. Battery post goes to the battery (of course), fld (+) goes to the ignition and voltage regulator wile the fld (-) goes to voltage regulator.
Thanks for the help,
Davidson
75 Duster 225, A904, MSD, striped interior, waiting for a supercharger and efi
76 Mustang II 302 auto - Not Stock
92 Loyal - Thats The One You Want!
PostPosted: Sun Jan 28, 2007 9:24 pm
Also what gauge wire should I use?
