It is currently Thu May 21, 2026 5:11 am
PostPosted: Sat Jan 27, 2007 9:48 am
The car has not been running of a few years :evil:,, is there a way to bench test the lsd unit.
225+0.080 at 10:1
268cam
holley 390
clifford headers
8 3/4 355's lsd
kh brakes
electronic ing
PostPosted: Sat Jan 27, 2007 10:12 am
If you see newspaper taxis at the shore, waiting to take you away to the rocking-horse people with looking-glass ties as you drift past the flowers that grow so incredibly high, then your LSD is working. ;-)
One crude but simple test is to jack up the rear of the car, block the driveshaft from turning (automatic trans in park, manual trans in 1st) and turn one of the rear wheels. If the other wheel turns the same direction, then your sure-grip is working at least to some degree. If the other wheel turns the opposite direction, the sure-grip's not working.
PostPosted: Sat Jan 27, 2007 12:02 pm
Another test is to jack-up one side and try to get the one wheel to turn. ( with trans in neutral, I use a "star bar" on a lug nut to get more grip) If you can get one wheel to turn with low effort, that tells you the the clutch or cones in the sure grip unit are worn.
PostPosted: Sun Jan 28, 2007 7:50 pm
Thanks
225+0.080 at 10:1
268cam
holley 390
clifford headers
8 3/4 355's lsd
kh brakes
electronic ing
PostPosted: Mon Jan 29, 2007 6:43 am
Are you sure about the wheel turning in the same direction?
I would think that if the driveshaft was not turning and your were able to get both wheel turning in the same direction that would mean your ring and or pinion is broken.
I think the other wheel will always turn the opposite direction. It just of matter of how much effort it takes.
This seems like the best way because it slitely loads the rear. I not sure but it seems to me the more LSD tighten up when loaded- beyond their normal preload.
PostPosted: Mon Jan 29, 2007 7:26 am
Yup.
PostPosted: Mon Jan 29, 2007 8:18 am
Please explain how this is possable :?:
PostPosted: Mon Jan 29, 2007 11:50 am
I'd love to, but I can't remember! :shock:
And now that I think of it, perhaps for the "both wheels one direction" test, the driveshaft must be unlocked.
PostPosted: Mon Jan 29, 2007 12:00 pm
:wink: :D
PostPosted: Mon Jan 29, 2007 6:50 pm
just go out to a backstreet and see how many black stripes you leave. :lol:
you want both wheels turning in the same direction because that means that the "limited slip" differential is doing its job. it is limiting slip and making sure sure both wheels are recieving power.
zedpapa
1970 dodge dart w/225 /6 bored .040" over, holley 390cfm w/vac. sec., compcams 252s, clifford shorty headers w/2.5" exhaust w/flowmaster, f-body 11" front discs, aluminum A-833OD, 8 1/4 w/3.21 SG
soon to have 5 gears!!!
