It is currently Tue May 19, 2026 10:42 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
 Post subject: Timing gear installation
PostPosted: Mon Feb 11, 2002 3:50 pm
Hey all. Is it normal to have to tap the timing
gear on the crankshaft when replacing the timing
set? The original came off pretty hard with the
correct puller and then I had to tap the new one
on with a small piece of pipe over the crank end.
Is this normal? Is there a chance of messing up
the thrust bearing?
I didn't hammer, just had to tap probably 100-150
times with a small body hammer.
Thanks
Mike
mike.j.moser@boeing.com
PostPosted: Mon Feb 11, 2002 4:37 pm
Just a quick trick I learned from my grandfather and some friends is to bake the crank gear, or heat it with a propane torch to get it hot enough to expand. It should just slip on the crank and when it cools it'll be snug as a bug.
PostPosted: Mon Feb 11, 2002 6:10 pm
: Just a quick trick I learned from my
: grandfather and some friends is to bake the
: crank gear,
My wife REALLY hates this part of engine assembly! I've also been known to bake the Harmonic balancer too. About 225F for a half hour or so, a little orange sauce on the side......yummmmm. A pair of welding gloves really comes in handy. I usually end up buying new hot mitts if I don't have welding gloves.
Gilly
tlg225ccr@aol.com
