It is currently Sat Nov 21, 2026 10:49 am
 Post subject: Cam Selection?
PostPosted: Thu Feb 01, 2007 3:26 pm
I want to get in on the Earson Cam GB,and could use some suggestions on which cam to go with.
What are the benifits of a dual pattern cam? The car is a 1976 Dodge Dart Sport Lite :
225 Slant
A-833 o.d
3.55 or 3.91 gears
This is going to be a daily driver. I am going to have the head ported/polished with oversized valves 9.5 or 10 to 1 comp (needs to run on 91) Clifford intake and 500-600 CFM carb,and clifford headers into single 2 1/4 exhaust.
I want a cam that will be good for daily driving,and make use of all of the head work a bigger carb. Any suggestions?
Thanks
PostPosted: Fri Feb 02, 2007 8:49 am
Anyone :?: :D
PostPosted: Fri Feb 02, 2007 1:51 pm
I think everyone has been talking about it here:
http://www.slantsix.org/forum/viewtopic.php?t=21698
PostPosted: Fri Feb 02, 2007 7:57 pm
I have been checking on that post,and I still dont really get it???
Really all I want is a Suggestion for which "off the shelf" cam I sould go with on my build.
Thanks :D
PostPosted: Fri Feb 02, 2007 9:32 pm
Your choice will be basd on personal taste.
If you want something smoother and maybe easier to drive, go with the 270.
If you don't mind a choppy idle and a bit more tempermental at low speed, go with the 280, make sure your compression is on the upper end of your 9.5-10.0:1 range. Although this cam will probably be faster with what you have, keep in mind it may be uncomfortable for your driving tastes.
Unless you really know what you need, stick with a single pattern cam. I don't think a dual pattern with more exh duration is the way to go in most combos. If anything, a dual pattern with more int duration may be the best, there's a reason the factory Hyper-Pack cam had more int dur.
After thinking about it and you are still unsure which one, be conservative a go with the 270. Later if you feel you want more, go with the 280. If you go 280 first and get aggravated with it's manners, you'll be in a bad mood when you change it out and you'll dread the work. If you go 270 first and want more, you'll be excited about the work as you change it in hopes of more power.
Slant Cecil
PostPosted: Fri Feb 02, 2007 9:36 pm
Thank you,that was very well put! I used to drive an SRT-4,so I am used to kind of a rough idle,and choppy low speeds.......but I do want my car to be a nice driver......except when I get on....then I want it to punch me in the face,throw me over its shoulder and take off like a bat out of hell :twisted:
PostPosted: Sat Feb 03, 2007 5:43 am
Why not just give Erson a phone call, and ask their recommendation. Tell them what your parts are, and what you want from the car. That's what I did, and Bob was very helpfull. They will know more about what will work for you, then all but a very few on this board.
Users browsing this forum: Bing [Bot], Google [Bot] and 7 guests
