It is currently Tue May 12, 2026 10:33 am
 Post subject: Timing gear - to the Doc
PostPosted: Wed Feb 13, 2002 6:26 am
So Doc, did I damage anything taping the timing
gear on the crank like I did? (ref: post on
monday). I didn't know the heating up trick.
Thanks
Mike
mike.j.moser@boeing.com
PostPosted: Wed Feb 13, 2002 7:52 am
: So Doc, did I damage anything taping the timing
: gear on the crank like I did? (ref: post on
: monday). I didn't know the heating up trick.
#3 main bearing, thrust surface, front side.
Check the end play in the crank, more then .008 and I would take a look at that surface.
Is the oil pan already on?
The proper damper installation tool and some heat installs these quick and easy.(If you must "tap" on a damper, always stand the engine assy on end, with the crank flange resting on a solid surface, like a concret floor. Use a piece of hardwood or soft metal to tap on and never hit the outer ring)
PostPosted: Wed Feb 13, 2002 9:18 am
Hey Doc, can you pull just the #3 main bearing
cap to inspect the bearing, or do you have to
loosen all the caps to re-torque??
Thanks
Mike
: #3 main bearing, thrust surface, front side.
: Check the end play in the crank, more then .008
: and I would take a look at that surface.
: Is the oil pan already on?
: The proper damper installation tool and some
: heat installs these quick and easy.(If you
: must "tap" on a damper, always
: stand the engine assy on end, with the crank
: flange resting on a solid surface, like a
: concret floor. Use a piece of hardwood or
: soft metal to tap on and never hit the outer
: ring)
PostPosted: Wed Feb 13, 2002 11:46 am
: Hey Doc, can you pull just the #3 main bearing
: cap to inspect the bearing, or do you have to
: loosen all the caps to re-torque??
It is OK to just remove, check and retorque a single main cap assembly.
Look carefully at the side thrust face, see any displaced (smashed) babbit? Also measure the thickness of each side with a micrometer.
