It is currently Tue Nov 17, 2026 11:29 am
Post new topic  Reply to topic  [ 34 posts ]  Go to page Previous 1 2 3
PostPosted: Mon Feb 05, 2007 12:46 pm
By the way, how do you get a posting here to show up as a link that can simply be clicked on? I was under the impression that typing .com did that, but apprently not.
Sam, to do that you begin the address with the "url" tag and end it with the "/url" tag. you can either type those in square brackets "[]" or use the URL button above the message composition window. Just click the button which inserts the tag then type your link address then click the button again to insert the closing tag.
Just FYI, using "code" tags you can type the example directly to eliminate any possible confusion... I've seen enough people on this forum use goofy formatting to explain proper usage of tags so many times that I've begun wondering if people know that's what code tags are for. To answer the question, a link would be typed like this:
Code:
[url]www.slantsix.org[/url]
Used to own:
'82 Dodge D150
Erson 270 Cam, O/S valves, mild port work, ~9.5:1 compression
Currently fighting with an '85 VW Cabriolet
My other passion
 Post subject: just for you Ron!
PostPosted: Wed Feb 07, 2007 3:11 pm
I have started on your turbo header. I will be posting some pictures later tonight on my website.
PostPosted: Wed Feb 07, 2007 6:05 pm
Code:
Well, ya learn something new every day! Even at my age. Thanks!
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
 Post subject: header
PostPosted: Thu Oct 04, 2007 3:31 pm
I am going to try a different set up, moving the turbo forward towards the grill. I will be posting pics soon.
