It is currently Wed Oct 14, 2026 3:30 am
 Post subject: Distributor Doughnut
PostPosted: Sat Feb 03, 2007 9:54 am
How critical is it to have the rubber doughnut that goes between the distributor base plate and the block?
An old boy once told me that he could'nt get his kids slant to run right without it.
Thanks
PostPosted: Sat Feb 03, 2007 1:51 pm
The O-ring, you mean. You need it. Without it, the distributor drive pinion won't be spaced correctly to the cam worm, which will hasten the destruction of the drive pinion. Also, there'll be an oil leak. Also, the distributor can seize in the engine block. All for want of a 15¢ O-ring!
PostPosted: Sat Feb 03, 2007 2:12 pm
I wasn't able to find anything close to it locally and in my o-ring kits. I found some of those (and the skinnier one further down the shaft) on the dealer parts locater list.
PostPosted: Sun Feb 04, 2007 3:51 pm
Thanks for the responses.
I too tried various O-rings and found none that would fit "out of the box".
Where would I find the " dealer parts locator list".
Thanks again
PostPosted: Sun Feb 04, 2007 3:57 pm
Go find the O-ring you need at Small Parts, Inc.
PostPosted: Sun Feb 04, 2007 4:05 pm
Ok, I think there's 2 O-rings on the distributor.
1 is an O-ring up top where the shaft transistions to the flange (slight recess in the flange). and the other is on the shaft in the middle (more like a seal than an O-ring)
I haven't replaced the one in the middle of the shaft, but I did replace the one up top with an O-ring from a Harbor Freight collection of O-rings..........
PostPosted: Sun Feb 04, 2007 6:10 pm
Go to your mopar dealer parts counter. If you get an educated or old timer clerk and give them the part # they will see if they have it in stock or can do a computer search of dealers across the nation. If other dealers have them they will print you out a list with phone #'s you call and order over phone.
Its best if you go with part # in hand - most parts guys aren't willing to bust out the microfiche to find a part # for you.
PostPosted: Sun Feb 04, 2007 7:07 pm
P/N for the top O-ring is 2095 740, and the inner diameter is 1.068". Use Small Parts Inc. P/N ORB-121.
P/N for the bottom O-ring is 2095 630, and the inner diameter is 0.920". Use Small Parts Inc. P/N ORB-021.
PostPosted: Mon Feb 05, 2007 6:27 am
part # 2095740
CLAYTON AMERMAN INC PEAPACK NJ USA Phone: (908)-234-0143 / (908)-234-0100
SALUDA MOTOR SALES INC SALUDA SC USA Phone: (864)-445-2030 / (800)-849-0984
CORNER MOTORS INC CADOTT WI USA Phone: (715)-289-4311 / (715)-289-3221
PostPosted: Mon Feb 05, 2007 6:31 am
part # 2095740
part # 2095630
REAGLE DODGE BANGOR PA USA Phone: (610)-863-6900 / (877)-733-3634
H E WAGNER MOTOR SALES CO JOHNSTOWN PA USA Phone: (814)-536-0540
FRANKS SERVICE GARAGE INCORPORATED MONESSEN PA USA Phone: (724)-684-9100 / (724)-684-9101
SHERMAN CHRYSLER DODGE INC CLARION PA USA Phone: (814)-226-9550
WEEKLEY CHRYSLER DODGE JEEP CO BUTLER OH USA Phone: (419)-883-2461 / (800)-932-5539
LAMBERT AUTO SALES INC CLAREMONT NH USA Phone: (603)-543-0188 / (800)-639-2271
BROWN'S CHRYSLER-JEEP-DODGE, INC. PAINTSVILLE KY USA Phone: (606)-789-6676 / (606)-789-5301
HENDRICKSON ENTERPRISE IN BOONVILLE IN USA Phone: (812)-897-3695
GILLIS MOTORS INC HAYWARD WI USA Phone: (715)-634-2651 / (800)-427-4349
GESSWEIN MOTORS INCORPORATED MILBANK SD USA Phone: (605)-432-5501
RICKABAUGH MOTORS INC LYONS KS USA Phone: (620)-257-2381 / (888)-257-2382
JOHNNY ROBERTS MOTORS INC ALTUS OK USA Phone: (580)-482-1901
DELUXE MOTORS INC MILES CITY MT USA Phone: (406)-234-2980 / (800)-675-2980
BILL BUCKNER CHRYSLER JEEP DODGE, EMMETT ID USA Phone: (208)-365-4438
are the only dealers in the U.S.A. to have the o-rings
PostPosted: Mon Feb 05, 2007 12:28 pm
Thanks so much.
Great site.
Super Six Conversion Stromberg
PostPosted: Mon Feb 05, 2007 1:06 pm
Where do you guys find all the dealers that have stuff like this sitting on their shelves? I asked two different local dealers if they could get one for me, and they said that nobody (dealer-wise) had them anywhere in the US.
Used to own:
'82 Dodge D150
Erson 270 Cam, O/S valves, mild port work, ~9.5:1 compression
Currently fighting with an '85 VW Cabriolet
My other passion
PostPosted: Mon Feb 05, 2007 1:16 pm
This thread is growing ridiculous, folks. Why bother futzing around with dried-out old rubber O-rings from a dealer when you've been given an immediate source of fresh stock...?
PostPosted: Mon Feb 05, 2007 1:21 pm
I am a mopar parts dealer (who just happens to love the slant six and all of its glory)
PostPosted: Fri May 16, 2008 10:05 am
I had to dig up this old thread since I'm freshening up an electronic distributor for my '67 Valiant and I can't abide 30 year old o-rings. The small o-ring Dan listed appears to be correct, but the larger one I removed from the distributor is much thicker in section (about .170" now) than the ORB-121 Dan suggested and still bears some Chrysler blue paint on it's OD. I ordered ORV-318 which is nominally 1" ID 1 3/8" OD and 3/16" thick and appears to be the best match. I ordered a package of 5 since the smaller o-rings comes in packages of 10 at a minimum and I have two distributors to rework.
