It is currently Thu May 21, 2026 3:55 am
 Post subject: Rear End Ratio
PostPosted: Sun Feb 04, 2007 7:12 pm
How can I tell or figure out what ratio I have in the rear end of my D100? I doubt that it has the original rear end in it, but I do think it is a truck rear end. Davey
PostPosted: Thu Feb 08, 2007 1:07 pm
Look for a tag under one of the bolt heads, that will show the ratio.
If no tag, count the turns of the driveshaft per turns of the rear wheel.
Do you know if the truck has a limited slip type differentiial?
PostPosted: Thu Feb 08, 2007 1:28 pm
also if you feel like changing the fluid most of the time it will be stamped on the side of the ring gear
