It is currently Sun May 24, 2026 11:23 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 4 posts ]
 Post subject: there it went
PostPosted: Fri Feb 15, 2002 9:01 am
well the motor spun a bearing today. so the new one is all ready in the machine shop getting preped. .60 over bore, full grove bearings, APR bolts, I do need a windage tray and a cam. any info is helpful. I am going for a stronger then stock setup and switching to the forged crank.
andrew wagner
PostPosted: Fri Feb 15, 2002 10:14 am
: well the motor spun a bearing today. so the new
: one is all ready in the machine shop getting
: preped. .60 over bore, full grove bearings,
: APR bolts, I do need a windage tray and a
: cam. any info is helpful. I am going for a
: stronger then stock setup and switching to
: the forged crank.
: andrew wagner
I think you got your "money's worth" out of this engine!
How many "under Turbo boost" passes / blasts did you make on this stock engine, hundereds or "just" a few dozen?
 Post subject: Windage tray?
PostPosted: Fri Feb 15, 2002 3:23 pm
: the forged crank.
: andrew wagner
Mike was going to be making another run of trays this winter. He may have an extra one laying around. 308-324-3576
slantzilla@excite.com
PostPosted: Sat Feb 16, 2002 7:39 am
too many to count!!!I will be posting pics of the new build up on my site.
andrew wagner
: out of this engine!
: How many "under Turbo boost" passes /
: blasts did you make on this stock engine,
: hundereds or "just" a few dozen?
: DD
