It is currently Sat Nov 21, 2026 8:12 pm
 Post subject: Webber carb ?
PostPosted: Wed Feb 07, 2007 7:56 pm
Will the stock fuel pump keep up with 3 36mm webber side draft carbs? Also haw much will the timing need to be retarded?
Thanks TF
Even in moderation i am excessive!
PostPosted: Thu Feb 08, 2007 7:48 pm
SSRN National Champion
I would think yes it would . But the timing does not have any thing related to the carbs. That is a different subject. Thanks Ron Parker :D
Bagels On Juice Im On Boost
PostPosted: Fri Feb 09, 2007 8:43 am
I had a 32/36 Weber, and I could never get a completely smooth idle until I put a constant low pressure electric rotary pump on it. I made this switch after much research and talking to some reps who said that the Webers really like a (IIRC) constant pressure of 3.5 to 4.0 psi, 60-70gph.
Now maybe that was only for the 32/36.
I think racetep.com has an article about fuel pressure on a weber.
Regards,
Tim
My Swinger gets the Highlight Valet Parking spot over the German sports cars on the Sunset Strip. I love my Mopar.
PostPosted: Fri Feb 09, 2007 12:33 pm
I don't know where I read it, but I've heard the same info about Weber carbs... low and steady fuel pressure makes 'em run.
PostPosted: Sat Feb 10, 2007 12:20 am
Thank you for the help. The site helped alot corrected me in many ways :oops: . I Had assumed that the increse in a better air fuel mixture would require a retard but i guess that made me the retard. I can't wait to get this car running and tune it, should be a fun ride!
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 5 guests
