It is currently Fri Nov 20, 2026 2:08 pm
PostPosted: Fri Feb 09, 2007 4:14 pm
I'm trying to figure out what tools I need to remove the fill plug from my diff. I think it is a 7 1/4. I'm used to using a 1/2" extension to remove the plug, but this looks like some kind of Torx bit or something.
- Dan in Simi
'74 Dodge Dart Custom
PostPosted: Fri Feb 09, 2007 4:26 pm
Yes, the 1/2 square should do the job.
Call it an "8 point" socket, basically two, 1/2 squares shapes, off-set and super-imposed on each other.
PostPosted: Fri Feb 09, 2007 4:27 pm
Threads here and here.
PostPosted: Mon Feb 12, 2007 4:35 pm
SSRN National Champion
On a 8 3/4 that is easy I use a Alabama speed wrench. :D Thanks Ron Parker
Bagels On Juice Im On Boost
PostPosted: Thu Feb 15, 2007 7:50 pm
Doh! I *knew* I should have taken my tools under there and tried it. I suppose that's what I get for my laziness.
Black soup has been drained out and full synthetic 85w/140 has been filled...
Thanks... :oops:
- Dan in Simi
