It is currently Sun Nov 22, 2026 6:12 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 6 posts ]
PostPosted: Sun Feb 17, 2002 10:08 am
Hi all,
I have a 225 six with an offy 4bbl intake manifold, Holley 390CFM carb and 904 automatic trans. I need to get the kickdown linkage working properly, I almost burned up my trans. From reading previous messages on this site it looks like I need a Locker K.D. cable. Could somebody tell me where I can get one and about how much they cost. Thanks, Shannon
PostPosted: Sun Feb 17, 2002 10:11 am
Check in the Summit Racing catalog. I think I saw one there.
Gilly
PostPosted: Sun Feb 17, 2002 12:17 pm
: Hi all,
: I have a 225 six with an offy 4bbl intake
: manifold, Holley 390CFM carb and 904
: automatic trans. I need to get the kickdown
: linkage working properly, I almost burned up
: my trans. From reading previous messages on
: this site it looks like I need a Locker K.D.
: cable. Could somebody tell me where I can
: get one and about how much they cost.
: Thanks, Shannon
It's also possible to make your own kickdown cable, from a bicycle brake/shift cable. Not as nive looking but much cheaper, if function is more important than form.
Charlie
flturbo6@aol.com
PostPosted: Sun Feb 17, 2002 2:34 pm
Thanks for the information. I ordered the Lokar kickdown cable today from Summit. So should this cable kit bolt in and solve the problem without any other brackets or modifications?
Thanks, Shannon
: Hi all,
: Thanks, Shannon
PostPosted: Sun Feb 17, 2002 6:14 pm
: Check in the Summit Racing catalog. I think I
: saw one there.
: Gilly
I've bought 2 from Summit. They are around $50. You will have to build the bracket to attach the cable housing at the carb end, but it comes with everything else. They offer kits for the 904 and the 727. Different part numbers, same kit. Dennis
slantzilla@excite.com
PostPosted: Sun Feb 17, 2002 8:12 pm
Also, Lokar sells a bracket for Holley carbs so you may not have to custom make a bracket. Unfortunately they do not make one for Carter BBD's, as I found out the hard way.
dart270@geocities.com
