It is currently Tue Jun 23, 2026 5:23 am
 Post subject: Bright, Dim, Bright Dim
PostPosted: Mon Feb 12, 2007 6:07 pm
Hey i got an electrical problem sumwhere...well atleast i think its an electrical problem...for sum reason"just recently" my lights will dim ALOT when i stop an idle and then when i take off they get bright again :? I replaced the altenator, battery, battery cables, and sum wires that were burnt but it still seems to do it...i am stumped :? anyone got an idea of what it might be? :shrug:
 Post subject: lights
PostPosted: Mon Feb 12, 2007 6:26 pm
Well if your car is a manual i think i know what the problem is, as i went through this in my pickup. Everytime i push the clutch in the lights got brighter, BECAUSE my chassis was not grounded, thus when i pushed in my clutch, it created a stronger ground to my dash. Perhaps your situation is somewhat the same...i would check all my grounds and make sure your chassis and body are grounded.
Drive it like its stolen, and be glad im not YOUR son...
PostPosted: Thu Feb 15, 2007 10:45 am
Mine is an automatic..but i do see similar results when i tap the brake. Thanks ill take a look at all the grounds this weekend! :)
PostPosted: Thu Feb 15, 2007 4:20 pm
Also check to see how well it is charging. Take a multimeter while the engine is idling and check the voltage on the battery. It should read right around 14.3 volts at the battery.
70 Dart, 360, 727
