It is currently Sun Nov 22, 2026 9:40 pm
 Post subject: engine size
PostPosted: Fri Feb 16, 2007 6:25 am
What are the different block casting numbers to determine the engine size on a 63 truck
PostPosted: Fri Feb 16, 2007 7:23 am
the engine size is on the lip of the block just be hind altenator if the block has never been machined although i did disassemble a 225 stamped block to fined it was a 198. :?
PostPosted: Fri Feb 16, 2007 9:29 am
As terrylittlejohn said, the stamped number is right here,
unless the block has been machined. Between and below #1 and #2 plugs, beside the coil.
As I understand it, 198's and 225's use a common block. The cranks and rods make the difference. 170's have a different block.
Check out Doug's articles on BLOCKS and STROKERS
Users browsing this forum: Amazon [Bot] and 8 guests
