It is currently Thu May 28, 2026 4:28 pm
PostPosted: Tue Feb 13, 2007 10:40 pm
Has anybody bought and utilized the $675 Wilwood Heavy Duty Disc brake conversion kit for an A-Body? I ask because I am seriously considering this in replacement of my 9" drums. According to the site it will work with the 9" version.
 Post subject: brakes
PostPosted: Sat Feb 17, 2007 5:29 am
From what I understand they work quite well .The thing that I like is your tracking isn't changed much as when you swap to B-body spindles and upper control arms. good price when compared to other kits. Like you I really want to use these soon as my budget allows. Summit has a B-body kit for 449.00 with spindles! just have to find good used upper control arms. My ball joints are good so as you I want to do as little work as possible,but for the extra savings of 225.00 using the Summit kit you can also rebuild the front end, ???now I'm stuck on which way to go.
