It is currently Sun Nov 22, 2026 2:01 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 4 posts ]
 Post subject: carb and intake ?'s
PostPosted: Tue Feb 19, 2002 12:59 pm
Hey guys,
Got a question for ya... any idea where I could find a 2bbl Holley and an intake to go along with it for my '69 Cuda?? I don't really want to spend too much but if I have to, I will...
Thanks for the help.
Later,
Mike
bacarudaguy@aol.com
 Post subject: Re: carb and intake ?'s
PostPosted: Wed Feb 20, 2002 8:17 am
: Got a question for ya... any idea where I could
: find a 2bbl Holley and an intake to go along
: with it for my '69 Cuda?? I don't really
: want to spend too much but if I have to, I
: will... : Mike
Mike....first, refresh the memory....this is an E-body 'Cuda, right?....with a slant, right?
My first suggestion would be to hit the salvage yards and look under the hoods of Volare's and Aspens for a Super Six setup. That's a two-barrel manifold, with carb. Check the pickups and vans, too.
While you're there, get the air cleaner assy., and the kickdown linkage for the auto trans. (Well, if you need it)
That package should set you up with what you're trying to do.
Roger
GTS225@aol.com
PostPosted: Wed Feb 20, 2002 12:26 pm
:Roger,
'69 'Cuda's are still A-body's.. but that's ok... I'm near the Chicago area... any idea of any good junk yards??
Later,
Mike
: Mike....first, refresh the memory....this is an
: E-body 'Cuda, right?....with a slant, right?
: My first suggestion would be to hit the salvage
: yards and look under the hoods of Volare's
: and Aspens for a Super Six setup. That's a
: two-barrel manifold, with carb. Check the
: pickups and vans, too.
: While you're there, get the air cleaner assy.,
: and the kickdown linkage for the auto trans.
: (Well, if you need it)
: That package should set you up with what you're
: trying to do.
: Roger
bacarudaguy@aol.com
PostPosted: Thu Feb 21, 2002 7:36 am
: '69 'Cuda's are still A-body's.. but that's
: ok... I'm near the Chicago area... any idea
: of any good junk yards??
Mike.....was I brain dead that day or what.......I completely overlooked the fact that you posted it was a '69.
Sorry.....I'm over in Iowa, wouldn't have a clue what might be around the Windy City for yards. I suggest you try to find some of the smaller,out-of-the-way places. The bigger yards are gonna have crushed up the older stuff, (usually), but it's still worth a phone call. If nothing else, sit down with the phone book and start calling and asking for late 70's Chrysler products with a 6 cyl.
Roger
GTS225@aol.com
