It is currently Mon Nov 23, 2026 5:51 am
PostPosted: Sun Feb 18, 2007 6:00 pm
I'm unsure of what carb to use on my setup. I'm using a 2 barrel manifold and so far have been considering the stock BBD, because I've seen a few people turbo them, and the Holley 350/500. I need to know whats the easier and will handle boost well.
I was also wondering about fuel delivery. I've read you could boost reference the stock fuel pump by adding a pressure line to the filter vent? I would love to see some pictures of this. I didn't see anywhere on my fuel pump that looks like vent. And will this method handle 10psi max boost?
I plan on running around 4psi daily and maybe 8-10psi when I feel like driving. This will be a blow thru setup with a small intercooler and a T3/T4 turbo on a 170ci slant.
PostPosted: Mon Feb 19, 2007 12:37 pm
The vent should be on the bottom of the fuel pump. If you can't find one, make one.
I have a '73 Swinger in the garage right now undergoing the turbo conversion. I'm using an '80s 318 carb on a stock 2-bbl manifold. That doesn't necessarily make it the best choice, but it's the one I'm using. Just make sure you have tight throttle shafts (which is the reason I chose this carb out of a line-up of 3).
The bowl vent has to be referenced to boost (above the throttle plates) also. This car is getting MSD's Timing Master to retard timing under boost.
Mike
Recognized by US Federal Courts as a Fuel Economy Expert!
PostPosted: Mon Feb 19, 2007 1:41 pm
Thanks mike. I've read a lot of your articles and they've been a big help. I think I saw you over at Turbo Dodge too :)
I found a thread that helped me picture the boost referencing here: http://slantsix.org/forum/viewtopic.php ... +reference
Good point about the MSD. They seem to be fairly priced so I'm going to use one for cheap insurance. I know it's a necessity at higher boost.
Users browsing this forum: Amazon [Bot] and 7 guests
