It is currently Mon Nov 23, 2026 9:30 pm
PostPosted: Wed Feb 21, 2007 6:19 am
I have 2 different mopar purple shafts that I could choose from #4286678 and# 4286681. Which one would work for me better in a street/bracket racer application? I intend on decking the block and head cleaning up the ports (I can't believe all the flashing the left in the head getting rid of the has to help)
1.7/1.44 valves 4 barrel, headers.
Now on to valves I intend on installing 1.7 and1.44 valves. But what should I use for springs. Any idea were I could get the best deal on the whole set up valves guides seals springs and retainers. I see a guy that advertises on ebay and I've looked at SI 'S web site just not sure the best route to go. I will have this head ready for the machine shop shortly and would like to get the valve componets ordered.
Awhile back I remember seeing a cam comparision chart on here that should specs for alot of different cams could someone repost it or tell me how to find it. Thanks
 Post subject: cam
PostPosted: Wed Feb 21, 2007 12:12 pm
i would go with the 276/.490lift cam,the stock retainer are fine but use harden locks and teflon oil seals ,there a lot better than umbrela seals, valve spring should be single with dampers like stock 340s, mopars#p4120249, i hope your going to plane the head while if off, 9/1 compression is nice for the street, just do the math before milling the head
 Post subject: Cam Choice
PostPosted: Wed Feb 21, 2007 1:47 pm
This is just me cam & spring kit same co. no?'s on install .The smaller cam I think would be fine again this is just me.Valve install we use sleaves much cheaprer than guides.All the roundeee cars here have them last long time.Hope this helps
'72 Image Duster /6 with turbo build up
'03 Ram 2500 4x4 w/HEMI 5sp 4:10 posi
My Twister Page
 Post subject: Cam Chart
PostPosted: Wed Feb 21, 2007 3:23 pm
http://www.hal-pc.org/~bwhitejr/Slant_Six_Cams.pdf
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
