It is currently Fri May 15, 2026 2:02 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
 Post subject: boosting fuel pump
PostPosted: Fri Feb 22, 2002 10:53 am
anyone have info or pics on where on the fuel pump to drill and tap for line to boost using presure from the preserizes side of a turbo? I got a new replacement pump today and would like to modify it rather than the original one on the car.
Dan
reptylkrib@aol.com
 Post subject: Re: boosting fuel pump
PostPosted: Fri Feb 22, 2002 2:56 pm
the 2nd page of my web site has pic and a description of the one I did.
andrew wagner
: anyone have info or pics on where on the fuel
: pump to drill and tap for line to boost
: using presure from the preserizes side of a
: turbo? I got a new replacement pump today
: and would like to modify it rather than the
: original one on the car.
: Dan
http://home.earthlink.net/~mrdartgt/
PostPosted: Tue Feb 26, 2002 8:02 am
Here is a PIC of a high volume pump with a 1/16 NPT fitting installed so a plastic tube & ferrel can be installed. (the same stuff used on mechanical oil pressure and vacuum guages)
If your pump does not have a lot of extra metal around the vent hole, you can also use a hose "bib" fitting like the ones pressed into carbs to accept the small vacuum advance hose. shoot for a tight press fit and use a little epoxy, the hose must be strong enough to hold the boost and be clamped so it won't pop-off under pressure.
