It is currently Wed Oct 14, 2026 10:33 am
PostPosted: Sat Feb 24, 2007 4:16 am
notice the flange is different not as thick as the intake I have some ideas but welcome more input thanks Don
'72 Image Duster /6 with turbo build up
'03 Ram 2500 4x4 w/HEMI 5sp 4:10 posi
My Twister Page
PostPosted: Sat Feb 24, 2007 8:31 am
Car Model: 1967 Dodge Dart 270
I had the same problem with my clifford headers. I used the thick gasket from Cox bros. and just bolted it together. The difference between the intake and header flange thickness is very clear. This is on a race car and I have not had any problems with leaks. I'm sure some machine work can be done to the intake to correct the problem.
PostPosted: Sat Feb 24, 2007 10:18 am
Hooker provided special spacers to make-up the difference.
Sounds like you will need to take some measurements and make some spacers.
These are best discribed as 1/2 washers, appx 1/8 thick. I usually tack weld them to the header flange so the don't get lost.
PostPosted: Sun Feb 25, 2007 3:40 am
thanks for your input dont remember that with my first set and thay were clifford but long time ago I was only 17 or so, hay doc thats what we had in mind we purchased half moon key ways measured thicksness I need this to work correctly and look good to! Dodgegirls 72 Blue sky Duster
My Twister Page
PostPosted: Sun Feb 25, 2007 4:01 am
Clifford uses a thicker flange, then the Hooker or MP headers
PostPosted: Sun Feb 25, 2007 4:19 am
Hello Charrlie is clifford the only one offering this?
My Twister Page
PostPosted: Sun Feb 25, 2007 6:01 am
As far as ready made headers, Clifford is the only one currently using the 1/2 thick flange. There are some suppliers offering the flanges alone in the correct thickness.
PostPosted: Sun Feb 25, 2007 6:57 am
Like Doc said. As far as I know Clifford is the only one with a 1/2 thick flange. If Harold ever gets the spitfires done, they will have a 1/2 flange. There are flanges available to build your own headers.
PostPosted: Sun Feb 25, 2007 9:02 am
I used the regular crescent shaped manifold washers on mine under the side of the factory crescent washers.
Don't you need to run Clifford intake with the Clifford headers?
The Mopar Performance headers I didn't install had some nuts welded to the flange. factory or not? I couldn't tell as I bought them used.
 Post subject: Mopar headers
PostPosted: Sun Feb 25, 2007 10:32 am
Yep when I pulled mine out of the box the nuts were welded on from the factory.
PostPosted: Sun Feb 25, 2007 10:35 am
No, Clifford headers will work with any intake.
A Clifford intake will not work with all headers though. The rear tube on the MP/J&R headers will hit the rear runner.
Yes, MP have the 1/4" nuts tack welded into the proper locations. :D
PostPosted: Sun Feb 25, 2007 12:47 pm
does anyone know about Offenhauser Single Quad Intake Manifolds
flange on this intake what header will work with it
PostPosted: Sun Feb 25, 2007 3:48 pm
That was my idea. Tack welding nuts on the header flange. Mister Twister decided to use half moon key ways(sp?) instead of nuts. It DOES look better.
PostPosted: Sun Feb 25, 2007 3:57 pm
Any header for the vehicle, should work. If there is a flange thickmess difference, just do like Dodge Girl and Mr Twister did.
 Post subject: 1/2 in flange
PostPosted: Tue Feb 27, 2007 4:24 am
Where? oh if I only had some to go with my new P.B.2000*and we got a RARE box with factory bending specs 60,70,80 auto's to make pre-bent tail pipes,axle over,motor to muff and much more. /6 to 426 hemi cars and trucks single and duels,all other auto makers as well DON send us your project.
My Twister Page
Users browsing this forum: Google [Bot] and 18 guests
