It is currently Mon Nov 23, 2026 6:41 am
PostPosted: Sun Mar 04, 2007 5:05 pm
Car Model: 1974 W100; 72 Dart
i have a 904 tranny out of an 85 Dippy. IF i wanted to use an electronic speedometer, what would i look under to get the correct pinion/sending unit?
sb
PostPosted: Mon Mar 05, 2007 6:12 am
How about one of GPS speedometers instead?
 Post subject: wow.
PostPosted: Mon Mar 05, 2007 7:19 am
that's pretty cool. i had not seen those.
i may do that if my search for the factory transducer(?) doesn't pan out.
sb
PostPosted: Mon Mar 05, 2007 7:45 am
I am guessing that you can use NAPA Echlin VSS 103 or Standard/BlueStreak SC-105, vehicle speed sensor that'll fit in place of the '66-up speedo pinion adaptor and accept the speedo drive pinions for a '94 Dakota, but put out a pulse signal rather than rotary motion to transmit to a cable:
The question I cannot answer is whether the late-model speedo drive pinions will work correctly with the earlier transmissions. I am guessing (again) that they will, but this would be a "try and see" operation.
If you wind up with a "tough luck, won't work" situation on the speedo drive pinions, you can leave the existing '85 speedo pinion adaptor in place and install an Echlin VSS 232 in series with the cable:
And if all else fails, there is an aftermarket kit that does kinda what you want.
PostPosted: Mon Mar 05, 2007 9:48 am
Dan, all the info i needed, thanks.
i will now go armed into NAPA, cuz that is the ONLY way i get help at the local one.
sb
PostPosted: Mon Mar 05, 2007 3:16 pm
Hey, another idea here. If I remember right, my 90 Dakota still had a cable driven speedo with the electronic provisions for the computer plug as well, both built into the speedo pinion adapter. I know that the late 80s FWD cars and minivans used this setup.
Users browsing this forum: Bing [Bot] and 6 guests
