It is currently Wed Aug 12, 2026 3:41 am
 Post subject: Lifters ?
PostPosted: Tue Mar 06, 2007 7:50 am
I was just looking in the tiny little mopar performance book that is still left and I was looking at the hemi section and I saw the solid lifters they sell are .005" undersized and I remember doc said the slant six could use some massaging and somewhere else I herd the hemi lifters were the same size so I put 2 & 2 together and I was thinking would this be a short cut to boring out the lifter bores?
PostPosted: Wed Mar 07, 2007 5:03 am
I haven't seen a hemi lifter, but you also have to consider height, not just diameter. you might need new pushrod length.
the "cup" may also be of a different cone, leading to a sloppy fit of the pushrods.
just things to consider, but yours is a new idea. without two of them side by side right here next to me I can't really say it would never work.
its probably best to try to attract Doc's attention, then ask him.
PostPosted: Wed Mar 07, 2007 6:41 am
well im thinking about ordering one to compare side by side cuz my cost on a mopar performance lifter is only $6.60 ea
PostPosted: Wed Mar 07, 2007 8:07 am
Getting a sample is a good ides for the reasons listed above.
From past exp. this lifter will be a match and drop right in. (a .005 undersize easy drop-in)
.005 u/s concerns me a little, I have never run one that loose, I usually shoot for .002 -.003 clearance. I don't see any "show stopping" problems with that amount of looseness, the (cast iron) SL6 lifter bores are thick and solid so you are not going to hurt them.
PostPosted: Wed Mar 07, 2007 8:14 am
well in that case I might just take your original advise and massage the lifter bores a little
Users browsing this forum: Amazon [Bot], Rick Covalt and 7 guests
