It is currently Fri Jun 12, 2026 10:44 am
Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2
PostPosted: Thu Mar 08, 2007 5:49 pm
Take a look at our own Tom Drake's ride.
http://www.drakecoatings.com/DCI%20Racing.htm
Click on the thumbnails.
There have been three slant powered doorslamers, to turn in the nine's in the quarter.
Tom Drakes Simca
Charles Myers Arrow
Cox Brothers 66 Dart
There are others not far behind in the low to mid tens.
 Post subject: horsepower
PostPosted: Thu Mar 08, 2007 8:26 pm
My slanter stroked and poked to a 234 CID pulled 308 HP on the dyno with a 500 CFM AFB, 316 HP with fuel injection. No bottle and no blow.
Best time in the 1/4 13.62 @ 97mph 2900+ lbs in a 67 Dart.
PostPosted: Thu Mar 08, 2007 9:05 pm
My Slant :
238cid, 3.5" pistons, Rollmaster timing chain, Ford 302W inlet and exhaust valves with heavy duty springs etc., head ported, block decked, crankshaft ground, 350 Holley, Genie headers, cam specs .295"(cam lift)@ 280deg Exh .295"(cam lift)@ 270deg. I think .295" cam lift equates to about .445" valve lift.
Best 1/4 mile 16.3 @ 84mph, with a bit of wheel spin on launch and taking it to 5000rpm in 1st and 2nd. Using one of those online HP calculators this engine is making around 140hp at the wheels. This is with a 350 Holley. With a 4BBL carb soon to come it should go into the 15's. The engine should be making around 155/160 at the wheels................I hope.
PostPosted: Thu Mar 08, 2007 10:11 pm
I had my 67 dart on a dyno it ran 150 hp to the rear wheels and 229 foot lbs of torque with the nos turned off
 Post subject: Fast damn Americans
PostPosted: Fri Mar 09, 2007 7:58 am
Thanks Charrlie_S. The first time I played that video, it crashed my computer! Speed envy on the part of my iMac, probably. The sound alone was enough to get me on my feet. Mean looking car, too. :shock:
/6 '67 Barracuda convertible, electronic ignition, 4-OD, street cam, SBP KH discs, 3.55 SG 7.25" 1" t-bars. Bilstein.
340 '67 fastback, Doug Nash 5-speed.
1988 Toyota pickup work truck
 Post subject: Re: Fast damn Americans
PostPosted: Fri Mar 09, 2007 9:31 am
I'm not trying to take anything away from either car. Even though the Drake car is Quicker/faster then Tilleys, they are intended for totally different purposes. The Drake car is a "race" car, running alcohal. Tilley's car is a daily driver on gasoline.
