It is currently Fri Jun 19, 2026 9:23 am
 Post subject: Valve size
PostPosted: Tue Mar 06, 2007 7:47 am
First let me tell you what I have done to the head so far. Street strip port and polish. Gasket mach intake and exghaust. Shaved head .050. The stock valves weren't in great shape can anybody recamend a good valve size if I was to upgrade. I have the K64-240-4 comp cam kit that came with timing chain valve springs and lifters. Any info would be great.
 Post subject: valve size
PostPosted: Wed Mar 07, 2007 9:07 pm
well if u want good performance u will need to get the bowls opened up... the valves im using are out of a early small block ford they are a litle different in the lenght but if ur still running hydralic lifters they will adjust themselves
PostPosted: Thu Mar 08, 2007 9:32 am
Are the valve guides in good condition or do they need replacing?
A common size for 3/8 guides is 1.700 intake and 1.440 exhaust.
 Post subject: Valve guides
PostPosted: Fri Mar 09, 2007 1:42 am
Guides are good
Users browsing this forum: Amazon [Bot], Google [Bot] and 3 guests
