It is currently Fri May 15, 2026 11:02 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 6 posts ]
 Post subject: Spark Plug Tube O-Rings
PostPosted: Mon Mar 04, 2002 3:28 pm
Hey guys! Does anyone know where I can get the
0-rings for the aluminum spark plug tubes on my
motor? I didn't even know there was suppose to
be some until Doug said so.......I wonder if that's why my motor was so oily??
If no one sells these things for the vehicle,
what are the dimensions for the correct ones?
Thanks
Mike
mike.j.moser@boeing.com
PostPosted: Mon Mar 04, 2002 4:36 pm
: Hey guys! Does anyone know where I can get the
: 0-rings for the aluminum spark plug tubes on my
: motor? I didn't even know there was suppose to
: be some until Doug said so.......I wonder if
: that's why my motor was so oily??
: If no one sells these things for the vehicle,
: what are the dimensions for the correct ones?
Mike,
I searched for " o-rings " and found a nice thread with lot's of info and sources.
See the link for a "short cut"
o-ring Message Thread
PostPosted: Tue Mar 05, 2002 7:54 am
We picked up a engine gasket set at Autozone that came with them. It was a Felpro product, so the o-rings are out there somewhere.
Mike
: Mike,
: I searched for " o-rings " and found
: a nice thread with lot's of info and
: sources.
: See the link for a "short cut"
: DD
mkastelz@earthlink.net
PostPosted: Tue Mar 05, 2002 8:24 am
I think you can get them at NAPA. NAPA has alot of parts for the old Mopars.
: We picked up a engine gasket set at Autozone
: that came with them. It was a Felpro
: product, so the o-rings are out there
: somewhere.
: Mike
mwhitehou@netscape.com
PostPosted: Tue Mar 05, 2002 11:02 am
: I think you can get them at NAPA. NAPA has alot
: of parts for the old Mopars.
NAPA part number B45384 pack of six
Charlie
flturbo6@aol.com
PostPosted: Tue Mar 26, 2002 5:57 am
: Thanks
: Mike
If you still need them I think I have about 100 or so o-rings that are high-temp and last much longer than the originals. The best place to get these is from a bearing supply store. I used to get them from Motion Industries, part number 2-218. (Hey, you didn't check the Slant Six Parts List in the Articles section!)
Chuck
webmaster@omnipages.com
