It is currently Thu May 14, 2026 12:23 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 4 posts ]
 Post subject: turbo kit
PostPosted: Wed Mar 06, 2002 5:03 pm
I have the first on just about done.
It's a non-intercooled kit for the slant 6. It will fit in the abody dart W/power stearing. There is no blow off valve, so the boost should be set at no more then 8 lbs at the most. the kit comes with exhaust manifold that is modified for the small t3 from the 2.2 and 2.5 liter dodge cars from the mid 80's, piping from the turbo to the carb, boost refrenced stock fuel pump, and oil pan with oil drain. I used steel mandral bent pipe and a the silicone hose fitting is also included.
This kit uses the stock 2 barrel manifold. I can not include the turbo or the piping to the filter, oil lines, oil drain lines and the boost timing retard or blowoff valve. If you want any of these things we can figure out a way to get you going!
This kit is made to get you started and to take care of only the fab work involve in doing a turbo on a slant 6. The rest is up to you.
I also want to say that I have spent alot of hours under the hood of my car and in books reading about turbo charging. I got my car in the 15s with A setup that is close to the same. I will help you any way I can with your install, I will have pics on my web site of this setup by the weekend. I will also make custom parts if you want to use a different turbo or you want a intercooler ect. please contact by email or give me a call at (717)846-1570
price 650$
thank you!!
andrew wagner
mrdartgt@earthlink.net
 Post subject: Re: turbo kit
PostPosted: Wed Mar 06, 2002 5:28 pm
That's great! Can't wait to see some pic's, especially the manifold!
rosendalemj@yahoo.com
PostPosted: Thu Mar 07, 2002 12:26 pm
: I have the first on just about done.
: It's a non-intercooled kit for the slant 6. It
: will fit in the abody dart W/power stearing.
: There is no blow off valve, so the boost
: should be set at no more then 8 lbs at the
: most. the kit comes with exhaust manifold
: that is modified for the small t3 from the
: 2.2 and 2.5 liter dodge cars from the mid
: 80's, piping from the turbo to the carb,
: boost refrenced stock fuel pump, and oil pan
: with oil drain. I used steel mandral bent
: pipe and a the silicone hose fitting is also
: included.
: This kit uses the stock 2 barrel manifold. I
: can not include the turbo or the piping to
: the filter, oil lines, oil drain lines and
: the boost timing retard or blowoff valve. If
: you want any of these things we can figure
: out a way to get you going!
: This kit is made to get you started and to take
: care of only the fab work involve in doing a
: turbo on a slant 6. The rest is up to you.
: I also want to say that I have spent alot of
: hours under the hood of my car and in books
: reading about turbo charging. I got my car
: in the 15s with A setup that is close to the
: same. I will help you any way I can with
: your install, I will have pics on my web
: site of this setup by the weekend. I will
: also make custom parts if you want to use a
: different turbo or you want a intercooler
: ect. please contact by email or give me a
: call at (717)846-1570
: price 650$
: thank you!!
: andrew wagner
Any plans to sell just the Manifold or does it have to be the complete kit? Also is the manifold a cast or header type? I have missed most of the details of this setup. Thanks, Ray
Rszubart@Excite.com
PostPosted: Thu Mar 07, 2002 1:50 pm
I just posted some pics under the header and intake page of the website. I will have a new web site with in the month I will let you know when.
The oil pan in the pic is the one for my car but The others will have the drain in the same place.
andrew wagner
http://home.earthlink.net/~mrdartgt/
