It is currently Fri Jun 05, 2026 10:18 pm
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
 Post subject: Back to work
PostPosted: Fri Mar 09, 2007 11:37 pm
Well, a short sub-project turned into a long one... My vacuum booster diaphragm started leaking, so I replaced it. While it was off, I cleaned all the crud out of my master cylinder, lo and behold it started leaking and bypassing fluid (the crud must have been sealing it). Took it apart and there was plenty of metal-to-metal wear on the bore and the pistons, so I ordered a new master cyl from Napa. They ordered the wrong part twice, then said that the store that was supposed to have the right part couldn't find it on the shelf. I got a refund, and so I *finally* just today got a new Raybestos part from RockAuto. Slapped it in, bled about 20 oz of fresh fluid thru the system until clear fluid came out of each bleeder, and I'm good to go. It stops really well now, I didn't know what I was missing before.
So I say all that to say that Saturday I will finally be able to start diagnosing my distributor. During my cursory investigation I didn't see any obviously broken springs, but the flyweights were pretty rusty. I will update as I find out more. I did buy a set of brass feeler gauges; do I use the .006 or the .008 to measure the gap?
- Dan in Simi
'74 Dodge Dart Custom
PostPosted: Sat Mar 10, 2007 8:16 am
Use the 0.008" when you're ready to put everything back together.
 Post subject: Results
PostPosted: Tue Mar 13, 2007 11:17 am
I took the distributor apart, and everything looked ok. No broken springs or obvious problems. There was some pretty substantial wear on the nylon drive gear. I ended up buying a "rebuilt" distributor (many of the parts on it were in worse shape than my old one) and using a few parts from it to rebuild my old one.
Put it back together, and the timing is rock solid. I have more power, and detonation has been reduced.
The tag number is 3755470 with "33 3" in smaller numbers above that.
- Dan in Simi
 Post subject: what stamp...
PostPosted: Tue Mar 13, 2007 12:39 pm
Did you take the governor off the remanf distributor by any chance?
If so did it have a stamp on it? If it's better than 15 (like 11 or 9) then swapping tht guy in can net a little more power if installed and timed correctly too...
(not all parts on the 'new' remanf distributor are in good shape, I notice the after market reluctors in these are fairly out of 'spec' some times compared to the original mopar reluctors...)
PostPosted: Wed Mar 14, 2007 5:57 pm
I was timing my engine the other day, and I noticed that the timing mark was varying 3-4 degrees from where I set it. The engine was at idle (~700 RPM) with vacuum advance disconnected and the line from the carb plugged. I set timing for 10 BTDC as best I could, but the timing mark was varying between 13 and 7 degrees.
I've never really seen this before... What should I check? Or maybe it's my timing light?
Thanks.
First thing to check is the mechanical condition of the distributor- are the springs connected, in good shape, and does the mechanical mechanism move smoothly? Is the vacuum pot properly hooked up to the breaker plate, and does its spring firmly retract the breaker plate to the minimum advance positioin? If not, you might be lucky and all you need is a distributor rebuild.
But most likely its a sloppy timing chain.
Users browsing this forum: Ahrefs [Bot] and 8 guests
