It is currently Tue May 19, 2026 1:22 am
 Post subject: Slant 6 Engine Dynoed
PostPosted: Wed Mar 14, 2007 3:01 am
SL6 Racer
I recently had a 3 day visit from Dart 270 to Australia,So i pre assembed a spare slant race engine so we could do a couple of days of engine dyno work.This was the fist time i had engine dynoed a N/A slant in about 10 years.
First run it pulled 333 HP & 330 ft lb & after the first cam change it made 347 HP & 344 ft lb. That was as good as it got as we ran out of cams & heads & Lou had a plane to catch.I now have a couple more cams & things to try wich will happen soon.
The engine runs 3 x 45 webers & 100 oct gasoline.
More to come :
Cameron
PostPosted: Wed Mar 14, 2007 5:03 am
niiiiiiiiiiiiiiiiice!
:D
PostPosted: Wed Mar 14, 2007 5:05 am
Thanks for posting the info Cameron. :D
PostPosted: Wed Mar 14, 2007 6:48 am
Thats quite the spare engine.......
PostPosted: Wed Mar 14, 2007 9:05 am
It sounds like I need to assemble some of my spares! :wink:
Can you give us more details, like compression and cam specs?
PostPosted: Wed Mar 14, 2007 11:21 am
:shock:
Amazing. Makes me really want to start collecting parts for a race slant that I can swap back and forth with a mild daily driver slant.
PostPosted: Wed Mar 14, 2007 11:45 am
Car Model: 1962 Lancer 770
Cameron, Lou was telling me about this particular test this morning, and my jaw dropped, quickly replaced with a big smile. He was clearly a kid in the candy shop! Congrats, we certainly would enjoy some more details without giving away your secrets!
MJ
PostPosted: Wed Mar 14, 2007 6:11 pm
That's excellent. Congratulations!
DynoDave
1970 Plymouth Duster
1972 Dodge Charger Rallye
1977 Chrysler Cordoba
WPC # 12304
 Post subject: back home
PostPosted: Thu Mar 15, 2007 11:00 am
I am now back in VA from my second trip to NZ and Oz...
Had a great time in Sydney, Australia with Mr. Turbine.
The most notable part about that engine was the super fat torque curve - over 320 ft-lbs from 3500 to 5700.
I cannot emphasize enough how useful engine dyno tuning can be. We did cam swaps in <1hr and head/cam swaps in ~2hrs with 2 guys working. Adjustable cam sprocket made cam timing changes happen in 15 min. 5 cams, 3 heads, carbs, cam timing, ignition....
PostPosted: Thu Mar 15, 2007 11:37 am
Car Model: 69 Valiant 225, 70 with a 265, 70 with a 318
More to come :
Cameron
Numbers like that are why Cameron and family are regarded as Slant gurus in Australia.
Richard (aka Fingers)
PostPosted: Tue Mar 20, 2007 3:29 am
SL6 Racer
Tried another cam last weekend & gained a little more,354 @ 5900rpm.
1 more flat tappet on the way & then its time to test a roller.
To answer 1 of Dougs questions comp is 12 to 1.
More to come
PostPosted: Tue Mar 20, 2007 4:51 am
I've always heard that the 3 sidedraft Weber setup was the unbeatable combination on a slant.
Users browsing this forum: Amazon [Bot], Google [Bot] and 10 guests
