It is currently Mon May 18, 2026 1:22 am
PostPosted: Tue Mar 13, 2007 10:38 pm
I have heard the jeep cherokee rear ends are good for early a body racing. Is this true? I have a 96 country 2wd and a 92 larado 4wd. Which would be the better choice?
Thanks
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
 Post subject: a cuda
PostPosted: Wed Mar 14, 2007 3:05 am
hello 66 don't know about jeep rears thought you my be able to tell me a little about this car we saw while walking around the gold yard #1,2,3,4 www.stormcomm.net/moparsnmore/bcuda2.jpg
'72 Image Duster /6 with turbo build up
'03 Ram 2500 4x4 w/HEMI 5sp 4:10 posi
My Twister Page
PostPosted: Wed Mar 14, 2007 8:20 pm
Looks like a Cuda too me :D . 64 to 66 style Ill have to look at mine to see what year 65 or 66 most likely.
What else did you need to know?
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Wed Mar 14, 2007 8:25 pm
The 4wd Cherokees with the tow package are supposed to have Dana 44 rears. "Regular" Cherokees have I think Dana 30 or 33 rears.
- Dan in Simi
'74 Dodge Dart Custom
PostPosted: Thu Mar 15, 2007 5:51 am
the xj cherokees ( box cherokees ) only came with the 8 1/4 and the dana 35 I would STRONGLY recomend not going with the dana 35 the grand cherokees only came with the dana 44,35 do not use any dana out of a jeep (the new dana does not compare by far from the old dana)
PostPosted: Thu Mar 15, 2007 6:14 am
... I would STRONGLY recomend not going with the dana 35 ...
Why?
PostPosted: Thu Mar 15, 2007 7:26 am
well I work a jeep dealer parts counter and the dana 35 has a big problem with the axle seals leaking and the parts alone at list price are $150 each axle price 9 (matrix priceing structure) is about $200 each axle cuz to get the seal off you need to cut the snap ring and bearing off to get to the seal, book calls for 2 1/5 hrs each side also any dana iv ever seen come threw the shop has a howling sound ( the carrier bearings are junk I carry about 20 sets of them in stock for each dana axle ) and also you NEED to use synthetic gear oil in them or they will burn up real fast list price on the recomended gear oil is $26.00 a qt holds almost 2 qt
PostPosted: Thu Mar 15, 2007 3:48 pm
Both of my jeeps are the box type. How do I tell if they are 8 1/4 or Dana? Do you happen to know the flange to flange measurments. If they are 8 /1/4 are taller gears available? I have heard that the 8 1/4 is good as a /6 race rear, anyone know if this is true? Did these rears come as a sure grip? I think the 92 4wd might be suregrip.
Thanks
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Fri Mar 16, 2007 12:59 am
Well, I don't have a ton of Jeep experience, but the Dana 35 rear in my buddies XJ (all unibody Cherokees are XJs, BTW) was pretty much indestructible, he drove it forever with black sludge in it and it just wouldn't quit. It never leaked. The Dana 30 in the front was another story, it leaked like a sieve and was noisy.
Most if not all 4wd XJs had "Command-Trac" or "Select-Trac," which is NOT a limited-slip differential but just a cool name for the transfer case.
You might try some of the articles on www.jeeptech.com under the axles section.
- Dan in Simi
PostPosted: Fri Mar 16, 2007 4:34 am
Thanks
Frank
The Mopar 8 1/4 rear is a acceptable rear for racing. But it needs to be from an 1970's "A" body, to get the correct width and spring perches. I don't think the 8 1/4 in a jeep is the same rear. Someone confirm this?
PostPosted: Fri Mar 16, 2007 10:30 am
if you send me the last 8 of your vin I can tell you the type of rear and the gearing also if it is limited slip or not , the xj cherokees only came with a dana 30 in the front (also if it is a dana axle front or rear you can check the fill plug 99% will have the dana diamond stamped in it ) also jeep never used a dana 44 in the front of the cherokee or the grand cherokee the only one that used a dana 44 in the front was the wrangler rubicon
PostPosted: Fri Mar 16, 2007 10:31 am
also I think the jeep rears are a bit to long for the a body
PostPosted: Mon Mar 19, 2007 5:58 am
I saw an 8 1/4 in the JY in an Aspen 4 door. They are out there.
PostPosted: Mon Mar 19, 2007 5:05 pm
The barracuda is a 64 or 65. If the trunk says valiant it is a 64. The 8.25 axle was standard issue in countless chyrsler vehicles and may still be in production for the dakotas. They are definately out there. Any F deriavative (aspen,grand fury,dippy) could have had them, some did come with the 7.25. It's true that it is a PITA to change axle seals on the dana axles, but it is the same procedure as changing them on the 8.75.
PostPosted: Mon Mar 19, 2007 7:27 pm
SSRN National Champion
I have a 65 Baracuda that says Valiant on the steering wheel but no where else. Thanks Ron Parker :D
Bagels Juiced Im Bamboozled
