It is currently Tue Oct 13, 2026 1:27 am
 Post subject: Flywheel?
PostPosted: Thu Mar 15, 2007 12:48 pm
just a quickie does anyone know if their is a difference between the flywheel for a cast crank and a forged crank?
PostPosted: Thu Mar 15, 2007 3:39 pm
No, there is not. :shock:
The cast clankers are still considered internally or neutral balanced. :D
The Mopar books list a different damper for cast and forged, but they will interchange too. :shock:
PostPosted: Fri Mar 16, 2007 4:46 am
thats cool cuz I just got a bell housing off a 78 in the junk yard but I didn't grab the flywheel cuz I figured it was different but they did have a 70 I could grab one off of
cool thanks man
PostPosted: Fri Mar 16, 2007 6:58 am
No, there is not.
Big D is correct, you can interchange any flywheel in the slant series except for the big 11" version used on HD trucks (low mount starter) and some 60's B/C body cars (police/Taxi) that used a similar HD clutch setup.
On another note, if you decide to use a truck flywheel these are a bit lighter than the car flywheels (which in every car case I've seen they have a thicker "band" around the outer edge of the wheel itself next to the starter ring)...so if you can't find a car version, you can use the truck version...(with less rotating mass...)
FYI,
PostPosted: Fri Mar 16, 2007 11:06 am
The size of the register hole changed in 67 or 68.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
Users browsing this forum: Bing [Bot], Google [Bot] and 9 guests
