It is currently Tue Jun 23, 2026 10:22 am
 Post subject: No ignition spark
PostPosted: Wed Mar 21, 2007 1:35 pm
Hi,
I get no spark whatsoever, I just installed the fourth brand new ignition coil in two days and there is no spark. Changed twice the ignition box and the cables but nothing, just don't get a spark. Oh, and forgot to mention that the ballast resistor is brand new too, actually I have changed it also four times in two days, just in case.
What could be the problem?
Thanks.
My other car is... another DUSTER!!! .·.
PostPosted: Wed Mar 21, 2007 1:50 pm
Hi, Try the distributer cap and rotor.
PostPosted: Wed Mar 21, 2007 2:02 pm
Hey,
Brand new rotor and cap... there is no spark coming from the coil
Ed.
PostPosted: Wed Mar 21, 2007 2:09 pm
Time to start at the beginning. If you have an AC current DVOM, check to see if you are getting at least 1 VAC out of the pick-up. You could have a weak magnet in the pick-up or improper gap between the pick-up and reluctor. If that's good, check continuity between the 2 wires coming from the distributor to the ECU. Colors will be the same (brown and grey as I recall). Check for voltage at the + side of the coil. Should be at least 9 VDC. Then check the output from the ECU to the - side of the coil. If everything looks good at that point, PANIC!
Mike
Recognized by US Federal Courts as a Fuel Economy Expert!
PostPosted: Wed Mar 21, 2007 4:09 pm
...If everything looks good at that point, PANIC!
Mike
:shock:
Well, I don't know much about mechanics or the electrical system of a car... so I am pretty much in panic right know with all the technical stuff... anyways, a glimmer of hope is showing because the two wires coming from the distributor to the ECU are peeled and touching each other; could this be the problem?
PostPosted: Wed Mar 21, 2007 6:04 pm
Ummmm. Pretty good chance of that. It's a problem for sure, if not THE problem.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Wed Mar 21, 2007 6:45 pm
That problem shut down every car I ever had it happen to (2 cars and hopefully done counting).
Mike
PostPosted: Wed Mar 21, 2007 10:03 pm
Well, that ended up being THE problem... thanks for pointing that out. My slant now runs pretty cool (so far).
Cheers,
PostPosted: Thu Mar 22, 2007 2:44 am
Glad I could help.
