It is currently Tue Jul 14, 2026 10:50 pm
PostPosted: Wed Mar 21, 2007 10:49 am
Has anyone attempted this with engine in car?? There is an engine mount right below the pump, it looks impossible.
One thought that I had similar to changing out an engine mount would be to jack the engine up towards the drivers side, take the mount off, then change out the oil pump?
This may just be one of those things that she needs taken to a garage with a lift for. Just looking for advice.
63 Valiant 200 Signet Convertible 170/
63 Dart, 225/
68 A100 Pick-up 225/
2006 Mitsu Raider Quad Cab (Dakota) Mopar 4.7L
1992 Dodge Stealth RT (My Mid-Lifer) 3.0L 24V
PostPosted: Wed Mar 21, 2007 1:54 pm
I just went through that. You have to lift the engine up enough to clear. You will hit the torsion bar mount for the lower control arm. Try as I may, there was no way around it. Short cuts are leave most everything in place, and unbolt the whole radiator so it comes up with the engine and you don't have the coolant mess to deal with. You still have to unbolt the tranny though.
Mike
Recognized by US Federal Courts as a Fuel Economy Expert!
PostPosted: Sat Mar 24, 2007 5:49 am
How about using a frame lift (as opposed to a drive-on) that'll let the suspension relax when you lift the vehicle up? Still a no-go?
PostPosted: Sat Mar 24, 2007 6:26 am
Maybe you have an idea I didn't think about. Give it a try.
Mike
PostPosted: Sat Mar 24, 2007 7:27 am
Mike
I'll find out when I go to change out my pump (going to do the oil pump mod and press on a hardened gear from Doug), and the shop on base has frame lifts so hopefully it'll work out with minimal finagling.
