It is currently Fri May 15, 2026 1:42 am
 Post subject: bbd gas hog!!!!!
PostPosted: Thu Mar 22, 2007 8:56 pm
Ok so I'm getting 20.4 or so mpg with my holley 1945 right? and I rebuilt a bbd and got 17.8 mpg but I couldn't get it to tune so I got a carb from an auto store and no I'm stuck at 14.6 mpg! Now I did have a nylon dis gear eat its self so I changed it and put on a new timing chain at the same time. You guys time its the timing? Im stuck. thanks
PostPosted: Thu Mar 22, 2007 8:59 pm
I dont have an idle inrichment valve on the carb Im using and the other one had no provisions for one. Is that the isssue?
 Post subject: Re: bbd gas hog!!!!!
PostPosted: Thu Mar 22, 2007 11:50 pm
Buying a "rebuilt" or "remanufactured" carburetor at the parts store practically guarantees you will get garbage.
PostPosted: Fri Mar 23, 2007 4:55 am
Two things come to mind. You ask if we think it might be timing. Does this mean you did not set it with a timing light? The othjer item is related to the timing chain. It is possible the cam timing is off.
PostPosted: Fri Mar 23, 2007 6:57 am
The Valaint got unbelievable mileage when the chain skipped. Of course I had to drive at 30 mph in 5th gear....
Changing the chain reduced my mileage...but now I can cruise at 75 in 4th......
PostPosted: Fri Mar 23, 2007 8:09 am
Remove the parts store BBD and put the old one back on. Then adjust the metering rods as described here
PostPosted: Mon Mar 26, 2007 8:41 am
Guys dont get me wrong the car runs great with the carb it has on now but the old bbd wouldnt tune to save its life. I guess I'll rebuild it again and see if it wants to run right. I just thought that if my timing wasn't set just right it wouldnt use the gas in the cylinders the best. Thanks for the info on the rod ajustment I do have those measurements but maybe the carb wasnt cleaned out all the way. Oh by the way can you use a ebrok or afb accelerator pump in a bbd???
Users browsing this forum: Google [Bot] and 9 guests
