It is currently Sat Nov 21, 2026 7:07 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
PostPosted: Sat Mar 23, 2002 6:59 am
Hi Doc,
Has anyone out there ever thought of using an automatic transmission safety blanket on a 4-speed Bellhousing for some extra protection. As we talked before, having one clutch explosion and walking away unhurt is good, but probably lucky!!
With no bolt-on scattershield available I was wondering if the blanket may give some added protection. Your thoughts?? Would it be strong enough?? Waste of time??
Thanks,
Rick
rcovalt@innernet.net
PostPosted: Sat Mar 23, 2002 7:59 am
: With no bolt-on scattershield available I was
: wondering if the blanket may give some added
: protection. Your thoughts?? Would it be
: strong enough?? Waste of time??
Rick, I suggest that ANYTHING that can be done to reduce/eliminate possible projectiles from entering the passenger compartment is a good thing. While a trans blanket might be a bit pricey, it would at least slow down the pieces. You might want to check with the mfgr. and ask thier opinion concerning use for a clutch rather than an auto.
Just remember.....Don Garlits lost half his right foot in a clutch explosion; hence we now have rear-engine TF dragsters.
Roger
GTS225@aol.com
PostPosted: Sat Mar 23, 2002 12:42 pm
: Rick, I suggest that ANYTHING that can be done
: to reduce/eliminate possible projectiles
: from entering the passenger compartment is a
: good thing. While a trans blanket might be a
: bit pricey, it would at least slow down the
: pieces. You might want to check with the
: mfgr. and ask thier opinion concerning use
I'm watching one on E-Bay at $75.00 so it may not be too expensive to give it a try.
Rick
: for a clutch rather than an auto.
: Just remember.....Don Garlits lost half his
: right foot in a clutch explosion; hence we
: now have rear-engine TF dragsters.
: Roger
