It is currently Fri May 08, 2026 8:19 am
 Post subject: spring plates
PostPosted: Tue Mar 27, 2007 3:55 pm
Are the spring plates the same for 8 1/4 and 8 3/4 rears?
PostPosted: Tue Mar 27, 2007 4:32 pm
They should be. I think both had 3" axle tubes. :shock:
PostPosted: Fri Mar 30, 2007 7:44 pm
Does anyone know the U-bolt dimentions for the 8 1/4 swap? I want to have them made up. Or is this something Iam just going to have to mearsure?
PostPosted: Sat Mar 31, 2007 1:01 am
Made up? Why? These are common almost generic items... If I had to guess I would say 3" diameter x 8-9" length.
http://store.summitracing.com/partdetai ... toview=sku
You can probably find the generic non mopar performance ones cheaper.
