It is currently Sat May 16, 2026 6:44 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 8 posts ]
PostPosted: Tue Apr 02, 2002 10:56 am
Found this cam on E-bay. Think it'd make a good turbo/blower motor bumpstick with that short overlap. Would like your opinion.
Item number.... 1818138576
Sorry, still haven't got the link thing figured out.
Roger
GTS225@aol.com
 Post subject: Re: ebay SL6 Cam
PostPosted: Tue Apr 02, 2002 12:28 pm
: Found this cam on E-bay. Think it'd make a good
: turbo/blower motor bumpstick with that short
: overlap. Would like your opinion.
: Item number.... 1818138576
: Sorry, still haven't got the link thing figured
: out.
The link is as easy as a "copy - paste" into the Optional Link URL box below and name it with a title, You can also simple cut and paste the address right into the message like this:
<A HREF="http://cgi.ebay.com/ebaymotors/ws/ebayISAPI.dll?ViewItem&item=1818138576&r=0&t=0">http://cgi.ebay.com/ebaymotors/ws/ebayISAPI.dll?ViewItem&item=1818138576&r=0&t=0</A>
Anyway, that MP cam is pretty aggressive, has a 76 degree overlap and .528 lift, also note the loose lash settings. I would say it is too much for a turbo set-up.
ebay SL6 Cam Link
PostPosted: Tue Apr 02, 2002 1:49 pm
Hey Roger,
I 'think' this is the same cam that I was running in my dragster...oil pump/dist gear has some broken teeth. If you want the cam to play with/measure on, let me know and you can have it.
I did not measure the cam, but the previous owner said the cam was the MP 284 .528 cam.
regards,
mark
mldingba@rockwellcollins.com
PostPosted: Tue Apr 02, 2002 3:21 pm
Man, Koller must have found a truckload of those cams! Dennis
slantzilla@excite.com
PostPosted: Tue Apr 02, 2002 5:49 pm
How did the cam run before the O.P. gear stripped?
What was the RPM "sweet spot"?
: Hey Roger,
: I 'think' this is the same cam that I was
: running in my dragster...oil pump/dist gear
: has some broken teeth. If you want the cam
: to play with/measure on, let me know and you
: can have it.
: I did not measure the cam, but the previous
: owner said the cam was the MP 284 .528 cam.
: regards,
: mark
PostPosted: Wed Apr 03, 2002 7:08 am
: The link is as easy as a "copy - paste" into the Optional Link URL box below and name it with a title, You can also simple cut and paste the address right into the message like this:
DOH !! Some of the simplest things trip me up at times. I've been trying to cut/paste into the text box and keep overlooking the link box.
: Anyway, that MP cam is pretty aggressive, has a
: 76 degree overlap and .528 lift, also note
: the loose lash settings. I would say it is
: too much for a turbo set-up. DD
Sheeesh! I musta been really tired to think it would have been ok for a pressure motor.......I gotta stop this 3rd shift stuff and find me a day job. Thanks for the advise, Doug
Roger
GTS225@aol.com
 Post subject: Ran ok, see txt
PostPosted: Wed Apr 03, 2002 11:40 am
Hi Doc,
Best time of 12.06 @ 111. 1.9 60 ft times. In a 1550 lb dragster (with driver), 4000+ stall powerglide, 4.56 gears 10.5x30 tires. 390 Holley vac sec on Offy, 8.5ish compression. MP ported head (1.7/1.44).
I wouldn't call the idle 'lumpy', but I let it idle around 900 to 1000 rpm. It would have probably idled down to around 750 and might have sounded lumpy then. I did not notice a real sweet spot, but then I was probably 'on the cam' before the converter stalled also. It seemed to pull good to my 6,000 rpm shift point.
I felt the car should be much faster than it was, but the compression was a lot lower than I had been told, and I never really got around to tuning it much before the oil pump gear stripped.
I'm having a new engine built now at J&M, this will use the same head but have around 12.5 compression with a quench style piston similar to your previous effort. I'm hoping for low 11s/high 10s.
I hope this answers most of your questions.
regards,
mark
PostPosted: Thu Apr 04, 2002 10:51 am
Would a cam like that work in my van rebuild?
Just curious, it's got an auto in it - but I am thinking of putting the built motor in my 108 van now and it's got a 3 on the tree.
Anyway,
Thanks for any responses,
Talk at ya later,
Dan
WhaleMstr's Web Garbage!
gramma@dm-tech.net
