It is currently Thu Oct 01, 2026 9:28 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
 Post subject: a few questions
PostPosted: Sat Apr 06, 2002 11:45 pm
i just got 66 dart back from the engine shop, they put a remanned 6 in it. it idles choppy the guy at the shop said it was the carb, (someone put a rochester 2 jet on it before i bought it), what kind or carter or holly 2 bbl carbs did they use on these? Also was there a difference in gearing in the 904s? cause it takes off quick but it has almose nothing after that. Another thing, my gauges dont work nor do my winshield wipers but all the lights on the instrument panel come on. whats up with that?
please help me thanks
MIKE
axis_909@yahoo.com
 Post subject: Re: a few questions
PostPosted: Sun Apr 07, 2002 6:38 pm
There are some 2 barrel carbs from the Super Sixes that can be used. I don't recall a 2 barrel as stock on a '66. Also, low power could be a clogged muffler or tight valves.
The lights on the instrument panel are independant from the gauges and wipers. The gauge problem could be broken traces on the circuit board or a bad instrument regulator (maybe even a loose connector on the circuit board). For the wipers, check the switch and connections to the switch.
Chuck
: I just got 66 dart back from the engine shop,
: they put a remanned 6 in it. It idles choppy.
: The guy at the shop said it was the carb
: (someone put a rochester 2 jet on it before
: i bought it). What kind or Carter or Holly 2
: bbl carbs did they use on these? Also was
: there a difference in gearing in the 904s?
: 'Cause it takes off quick but it has almost
: nothing after that. Another thing, my gauges
: don't work nor do my winshield wipers but all
: the lights on the instrument panel come on.
: Whats up with that?
: Please help me, thanks
: MIKE
webmaster@omnipages.com
PostPosted: Mon Apr 08, 2002 6:07 pm
: i just got 66 dart back from the engine shop,
: they put a remanned 6 in it. it idles choppy
: the guy at the shop said it was the carb,
: i bought it), what kind or carter or holly 2
The '66 SL6 used a 1 bbl carburetor. A 2 bbl Carter BBD was stock on the '77-'80 super six engines. The 2 bbl Holley 2280 was an aftermarket replacement for the SL6 Carter BBD. If your '66 has a 2-bbl intake manifold, then it has been converted, and can use either of these carburetors.
Bob D
BBobbias@aol.com
