It is currently Fri May 15, 2026 11:00 am
 Post subject: /6 auto in '85?
PostPosted: Thu Apr 12, 2007 11:43 am
Would that be an A904 w/2.45 first, and lockup convertor? For a 2wd truck that is. I found through an earlier post that A998/9 were never placed behind /6's, so I'm wondering if it's wide ratio (2.74? found two different references) or not.
 Post subject: Re: /6 auto in '85?
PostPosted: Thu Apr 12, 2007 12:37 pm
Yep, it'll almost certainly be the wide-ratio A904 with 2.74 first and 1.54 second gear ratios. Lockup: Yes or no depending on how that particular truck was equipped.
PostPosted: Thu Apr 12, 2007 3:16 pm
Thanks Dan.
