It is currently Sat May 16, 2026 7:24 am
PostPosted: Sat Apr 14, 2007 4:31 pm
The pinion nut was missing from the rearend under my 62 Signet and the yoke worked its way off. This caused the rear to lock up so that i could not roll the car back and forth. Having a bout 4 other 7.25 rears laying around I decided to take the nut and washer off of one of them to remedy the rollability deficiency. To my chagrin I found that the nut that and washer that I took from another 7.25 differential would not fit on this one. It happens that one of the rear axles I have is from about a 74 Duster with large bolt pattern; the nut and washer from that diff fit fine and is 1/8" larger that the earlier one. I'm suspicious that the rear end in the Valiant has been changed out for a later model. The real question is this: The rear that I first robbed of its nut and washer is the one with a sure-grip in it. Will that sure grip accept the later gears and will it fit into the later housing?
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sat Apr 14, 2007 4:41 pm
I just went through the same thing ....pinion nut off and locked diff.
I put 65 gears in a 74 7.25 with no difficulty.
PostPosted: Sat Apr 14, 2007 4:58 pm
Well that's encouraging. Thanks for the quick answer.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
