It is currently Wed Nov 18, 2026 7:57 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
 Post subject: Which block is it?
PostPosted: Tue Apr 16, 2002 9:26 pm
Hi everybody,
Been scratching my head trying to figure out which slant six block I have. The main casting number (which is a long number on the forged crank block in my car) is 030-11. The rib on the water pump mounting flange is the same thickness from the outside to the block (so it's cast crank, isn't it?) Or is it? I can't find out anything about that casting number. I know that somebody or the Doc will know for sure. Thanks.
Patrick Devlin
pwd22@drexel.edu
 Post subject: Re: Which block is it?
PostPosted: Wed Apr 17, 2002 9:25 am
: Hi everybody,
: Been scratching my head trying to figure out
: which slant six block I have. The main
: casting number (which is a long number on
: the forged crank block in my car) is 030-11.
: The rib on the water pump mounting flange is
: the same thickness from the outside to the
: block (so it's cast crank, isn't it?) Or is
: it? I can't find out anything about that
: casting number. I know that somebody or the
: Doc will know for sure. Thanks.
: Patrick Devlin
It is a "Later" block, (78-84) most likly a cast crank. ( I say most likly because one racer I have talked with tells me he has a "thin water pump rib" block which has a forged crank in it. . . Uhhmmm (??)
Pop-off the pan and take a look, let us know what you find.
PostPosted: Wed Apr 17, 2002 7:00 pm
Got this motor up in an engine stand today, but it was too dark out by the time I finished to get a good look at the crank. I'll know for sure first thing tomorrow when I get home from work.
: It is a "Later" block, (78-84) most
: likly a cast crank. ( I say most likly
: because one racer I have talked with tells
: me he has a "thin water pump rib"
: block which has a forged crank in it. . .
: Uhhmmm (??)
: Pop-off the pan and take a look, let us know
: what you find.
: DD
pwd22@drexel.edu
