It is currently Fri Jan 02, 2026 10:46 am
 Post subject: header and intake ????
PostPosted: Sun Apr 08, 2007 5:50 pm
i was wondering what headers and intake that i should go with my 74 duster i want to get somemore power out of in i think about getting a 4 bbl on it but i am not sure what ones are the best
PostPosted: Sun Apr 08, 2007 7:52 pm
For the street, you can't beat a Super Six and Dutra Duals.
Far a race engine, use a Clifford intake and their shorty headers.
PostPosted: Mon Apr 09, 2007 6:23 pm
SSRN National Champion
Yep thats the deal Dutra Duals for the street . Aint so sure tube headers are any better at the strip. Thanks Ron Parker :D
Bagels Juiced Im Bamboozled
PostPosted: Mon Apr 09, 2007 7:28 pm
We will soon see how much difference there is between headers and Dutra Duals. I have a pair of the cast manifolds to put in the Piggie until Harold gets my Cliffords and step tubes to me. :shock:
PostPosted: Mon Apr 09, 2007 9:50 pm
My road toad Lancer does low 13's thru cast iron manifolds. :shock:
PostPosted: Sun Apr 29, 2007 8:21 pm
i am going with a offy 4 bll and Dutra Duals for headers
PostPosted: Sun Apr 29, 2007 8:29 pm
You slapping these on a stock engine or you doing a complete buildup? If it's stock I would STRONGLY recommend the Dutra Duals and a Super Six.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Tue May 01, 2007 8:55 pm
Hey
I run a Offenhauser intake with Dutra Duals with a mild cam and it works great!!
I spent enough time fighting with old Carter 2bbls and am much happier with the Holley 390.
PostPosted: Wed May 02, 2007 7:05 am
Hey
You must have found some lemon Carters, because the Carter BBD is one of the most reliable carbs ever made.
82 D150-225/727
PostPosted: Thu May 03, 2007 7:43 am
2bbl Thay were good back in the day. The last three we recived 1 was bad, it did not like to be wide open,got a bad flutter. Going to Holley on my set up! Hope this helps someone. Don
'72 Image Duster /6 with turbo build up
'03 Ram 2500 4x4 w/HEMI 5sp 4:10 posi
My Twister Page
PostPosted: Thu May 03, 2007 8:54 pm
The problem is that many of the ones left have the throttle shaft bushings worn out, leading to a host of issues. Unfortunately, rebuilders don't do the throttle shafts and the rebuilts have the exact same issues. :cry:
I ran a BBD on my Duster for a while that I had gotten the throttle shaft done on. It did work very well. :D
Users browsing this forum: Bing [Bot] and 6 guests
