It is currently Mon Nov 16, 2026 4:10 am
 Post subject: air cleaner
PostPosted: Mon Apr 30, 2007 5:39 pm
does anyone make an open element aircleaner to fit the holley 1920? about 10inch diameter?
PostPosted: Mon Apr 30, 2007 5:48 pm
Some people aren't crazy about an open-element air cleaner, but they look cool. :)
I have one(brand-new) for sale, but be warned: It's a "home-aid" version! :D
It looks like a hundred bucks on the engine, but it isn't as nice underneath.
PM me with your E-mail, and I'll send you some pics if you want.
BigBlockBanjo
225 Cubic Inches of Iron-Head American Muscle
225 bored .040 /.100 off block, Schneider Cam 224@.050~ .480 lift - Stock valves, blended bowls, Offenhauser intake with 500 Edelbrock carb
PostPosted: Mon Apr 30, 2007 7:05 pm
Open-element air cleaners look cool (some think) but they don't work as well as the factory units.
PostPosted: Mon Apr 30, 2007 7:08 pm
My point is made.....hehe :D
PostPosted: Mon Apr 30, 2007 8:20 pm
The unsilenced air cleaners used in the '60s are the same as an open element cleaner. The ones from '67-'69 were about 10".
Slant Cecil
PostPosted: Mon Apr 30, 2007 8:26 pm
WHYZAT?
PostPosted: Mon Apr 30, 2007 10:26 pm
Because Dan said so...
PostPosted: Tue May 01, 2007 4:37 am
Oh boy...
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Tue May 01, 2007 6:02 pm
WHYZAT?
He's referring to the fact that an open air element does pull in more hot engine air,... it forms a low pressure area over the carb inlet. (Because the air rushing straight through the element goes right over the top of the carb, causing a part-throttle stumble)
It's also harder to hook up a "positive"(?) PVC system....you have to run a small breather on the valve cover. I'm sure I forgot another reason.
Oh yeah, you lose your carb "hot-air" system.
Pro's and Con's. Just make sure you like it, it's your car. It's not like you can't change it right back if you don't like it.
My .02
BBBanjo
Users browsing this forum: DuckDuckGo [Bot] and 3 guests
