It is currently Mon May 18, 2026 6:09 pm
 Post subject: No Va
PostPosted: Wed May 02, 2007 8:30 am
A buddy of mine replaced a /6 in his 66 Val w/ AT. The motor started up wonderfully, but when he put it in gear, nothing. I have all clutch cars, so I had nothing to add. Is there somewhere for him to start looking. Maybe the torque converter?
/6 '67 Barracuda convertible, electronic ignition, 4-OD, street cam, SBP KH discs, 3.55 SG 7.25" 1" t-bars. Bilstein.
340 '67 fastback, Doug Nash 5-speed.
1988 Toyota pickup work truck
PostPosted: Wed May 02, 2007 10:45 am
Check the cheap and easy things first.
Fluid level?
Shift linkages / adjustment?
PostPosted: Wed May 02, 2007 11:00 am
Dis-connect one of the AT's coolent lines and start the engine, see if the trans is pumping fluid. (a section of rubber hose and a fluid catch can will reduce the mess)
Did he remove or change converters?
 Post subject: Thanks I'll Check
PostPosted: Wed May 02, 2007 11:09 am
His mom's in the hospital, but I'll have him start with these initial checks. Not sure about converter.
:idea:
PostPosted: Wed May 02, 2007 11:57 am
Hopefully the converter didn't slip out of place.
This may sound stupid, but, he did remember to put those 4 bolts back in between the flexplate and converter, right? EDIT: Ignore this, obviously he did if the car started otherwise the starter would just spin the converter in place.
Leave the car in reverse when checking the fluid lines as I believe thats when the most fluid is being moved.
PostPosted: Wed May 02, 2007 7:25 pm
Is he using a 66 auto trans, with a 68 or later converter? If yes the splines on the trans input shaft are not engaging the splines inside the converter. The 66 trans has a smaller diameter and different spline count then the later converter.
PostPosted: Thu May 03, 2007 1:43 pm
That's possible Charrlie_S, since I think it was a replacement motor with the 66 transmission. If it is pumping fluid, that would be the next thing to find out.
PostPosted: Thu May 03, 2007 4:37 pm
If it is the input shaft problem, the trans will pump fluid but the car will not move.
