It is currently Fri Jan 02, 2026 2:00 pm
Post new topic  Reply to topic  [ 24 posts ]  Go to page Previous 1 2
PostPosted: Thu May 03, 2007 4:01 pm
Sorry, but you can not run fast enough to give me a POS Tquad.
My gut instinct is to agree with you, but this guy, amongst others, seems to like 'em a lot.
I don't see where "this guy" is talking about a Thermoquad. I see him talking about a Quadra Jet but not TQuad. I am interested in reading about his opinion on the TQuad. Can you point to it please.
PostPosted: Thu May 03, 2007 6:30 pm
Er aaah Dan? He said Qudrajet in that linky. I said Thermoquad.
I like both. Got a Qjet on my van right now. It does better on gas than my TQ's. Just never really tried to tune the TQ's. The Qjet is a factory 87 or so 360 van unit.
'72 Duster 198 stock cam, 3:23's Hookers on jack stands for 8 years in the driveway
'79 Maxivan 360 Offy Qjet Comp RV cam/rusting in the driveway.
93 D350 160HP Cummins Auto :-( Dually Clubcab needs a injector pump
2005 Golden Couch Buick
PostPosted: Thu May 03, 2007 6:49 pm
Nope...'cause my brain musta been unplugged when I read Slantzilla's "Tquad" and somehow turned it into "Qjet"! :shock:
PostPosted: Thu May 03, 2007 7:22 pm
Gots2no the diffreance between the Thermobawg and the Quadrajunk!
Thanks for the link!
PostPosted: Thu May 03, 2007 8:50 pm
Qjet is a hundred times better carb than a Tquad. I have spent the time necessary to tune both. Tquads suck. :shock:
PostPosted: Fri May 04, 2007 4:15 am
Yep whatever! I gotz a strip kit so I am predjudiced :lol:
PostPosted: Fri May 04, 2007 4:49 am
I ve heard the Tquads had a composit center that had a tendency to warp. I thought that this was really the only problem with them. :shock:
PostPosted: Fri May 04, 2007 5:02 am
The bowls warp, but the O-rings under the main wells deteriorate and a lot of people don't know they are there. When that happens you get really, really bad gas mileage.
The main problem is that to be tuned properly they have about a dozen adjustments that have to be made in order, and to do them properly you really need some special tools.
Qjet you need only stuff that is in your normal tool box.
PostPosted: Fri May 04, 2007 5:20 am
Never had a problem with either of those 2 things. The warpage was common with the 71 models.
Good luck finding a 71! They are very pricey for cores!
I've only run TQ's on my van so far. Lots of heat in that engine house!
The jet wells fall off. They are glued on from the factory. An easy fix with JB Weld.
