It is currently Tue Nov 17, 2026 9:07 am
 Post subject: fusible link location?
PostPosted: Fri May 04, 2007 11:06 am
If and when i put in a fusible link in my 63 wagon, where in the line should i put it? If I put in a fuse how big 60 amp?
PostPosted: Fri May 04, 2007 11:37 am
You'd want to put it between the starter relay's big terminal and the firewall connector's big terminal, on the starter relay end of the wire that already runs between those two points. See discussion here, here, and here.
PostPosted: Fri May 04, 2007 11:59 am
read the posts recommended, but no mention as to location and amps of fuse or circuit breaker strength. I'm awaiting my fsm to fix my 63 and its KILLING me! I have a bad short :evil: I think i've fixed at least 10 bad connectors so far... :shock:
 Post subject: Re: fusible link
PostPosted: Fri May 04, 2007 12:06 pm
↑↑↑Read my reply in this very thread that you're reading right now...
Discussed in great detail at the linked threads, man! :shock:
Users browsing this forum: Google [Bot] and 7 guests
