It is currently Tue Nov 17, 2026 6:48 pm
PostPosted: Fri May 04, 2007 2:13 pm
Does anyone happen to know what the stock dimension should be for standard shackles on the rear leaf spring for a Dart?
PostPosted: Fri May 04, 2007 2:54 pm
3/8 x 4 1/2
I used 1/2 x 4 1/2 onthe set I just made
PostPosted: Fri May 04, 2007 3:38 pm
What is the distance between the holes you drilled?
Thanks!
PostPosted: Fri May 04, 2007 8:06 pm
Mine are 4 3/4 total length and 3 1/2 from the center of each bolt.
PostPosted: Fri May 04, 2007 8:09 pm
Thanks much!
Users browsing this forum: Bing [Bot] and 6 guests
