It is currently Fri Nov 20, 2026 6:27 pm
PostPosted: Thu May 10, 2007 1:18 pm
I have a new engine for my 87 D150 on the stand, with a 243 cam installed. On my first attempt to degree a cam, it looks to be 9 degrees retarded. Since the largest bushing is 8 degrees in my MP bushing kit, should I just put it in and run it at 103 degrees , or is there something else I can do to correct the cam timing?
PostPosted: Thu May 10, 2007 1:24 pm
103 will be fine. :shock:
PostPosted: Thu May 10, 2007 2:46 pm
How many degrees can you get by moving a tooth on the chain?
PostPosted: Thu May 10, 2007 3:46 pm
IIRC, one tooth is about 15 degrees. :shock:
PostPosted: Thu May 10, 2007 8:11 pm
So move it 1 tooth, and you're 6 degrees advanced....
Then back it off a little so you're slightly advanced....
PostPosted: Thu May 10, 2007 9:10 pm
Thanks slantzilla and emstivil. At 103 Wouldn't chain stretch retard the cam more soon after I got it running? Also, which way should I move the chain to advance the cam?
PostPosted: Fri May 11, 2007 7:01 am
The chain will not stretch any time soon. After many miles, you may have to think about chain stretch, but not for a long time.
As you face the front of the engine, the cam needs to be rotated clockwise relative to the camshaft sprocket. That is:
-Sprocket stays in the same position, camshaft moves clockwise
or
-Camshaft stays in the same position, sprocket moves anticlockwise
If you are working with offset bushings, the fat end of the bushing goes on the anticlockwise side, and the hole/thin end of the bushing goes on the clockwise side, to advance the cam. It's really easy to get crossed up when trying to picture this mentally, so take your time and draw pictures if necessary.
PostPosted: Fri May 11, 2007 2:40 pm
Thanks Dan, cam is now installed at 103
Users browsing this forum: Amazon [Bot], DuckDuckGo [Bot], Google [Bot] and 6 guests
