It is currently Sun May 17, 2026 4:09 am
 Post subject: Differential Oil
PostPosted: Sun Apr 29, 2007 1:33 pm
The specs for my 64 call for
Hypoid Lubricant
or
Multi-Purpose Lubricant
Is that equivalent to GL-4 or GL-5?
When did the GL-4 and GL-5 specs come out?
If it's GL-4, any harm in using GL-5? (I have some leftover GL-5 quarts)
PostPosted: Tue May 15, 2007 11:24 am
GL 5 is fine, so is GL 6. I like to run a synthetic 80-90wt since they meet the viscosity spec but flow much better cold and have less drag when hot too. Every bit helps when you have a small engine. Cost is not such an issue since it does not get changed very often.
