It is currently Fri May 15, 2026 1:25 pm
 Post subject: Mix'N'Match
PostPosted: Tue May 15, 2007 3:04 pm
I've got a pair of 8 1/4s , one is out of a Duster, and the other is from a deputized Diplomat.
I was thinking of mix'n'matching the two for application in my Scamp.
The plan is to use the Duster housing, and swap the gi-normous breaks from the Diplomat to it. Also the pinion snubber ('cuz it's a little taller) and potentially the gear set.
The Duster's gears are 3.21
The Diplomats gears are 2.9 (really? there is a second tag that reads 0558)
With an O/D A-833, which would be preferable?
Anybody see any potential problems with this plan? IE - the fact that the rear breaks will be MUCH larger than the front(still drums)?
PostPosted: Tue May 15, 2007 3:37 pm
What you are talking about here is hot rodding....fill yer boots.
Try anything you like but keep the old stuff intact till you know the new stuff works....
PostPosted: Tue May 15, 2007 6:56 pm
With an OD you will want at least a 3.21 or the OD will be relatively useless unless you drive 100 a lot. :shock:
