It is currently Thu May 14, 2026 2:33 am
 Post subject: Head Cold
PostPosted: Wed May 16, 2007 8:31 am
I've always torqued the cylinder head bolts when hot. If I'm assembling the head, what do people recommend for threadlocker, thread sealer and initial torque (cold)- I'm guessing one should re-torque when hot. Thanks for your input. I looked for a specific article on this forum, but didn't notice any.
/6 '67 Barracuda convertible, electronic ignition, 4-OD, street cam, SBP KH discs, 3.55 SG 7.25" 1" t-bars. Bilstein.
340 '67 fastback, Doug Nash 5-speed.
1988 Toyota pickup work truck
PostPosted: Wed May 16, 2007 9:43 am
I have never torqued the bolts hot, since the new gaskets do not need retorque. No threadlocker is needed, and I usually go higher (75-85 ft-lbs) than the FSM spec. I use oil on the threads, which some people don't like, but I've never had a gasket/bolt problem up to 11:1 and I've done 30-50 head swaps on Slants.
PostPosted: Wed May 16, 2007 10:23 am
Thanks Lou,
Maybe I'm thinking of some of the mainifold studs that need thread sealer because they are open to the water jacket?
PostPosted: Wed May 16, 2007 2:15 pm
Thanks Lou,
Just the end 2. The rest are blind holes. :lol:
PostPosted: Wed May 16, 2007 2:21 pm
The end near the thermostat?
PostPosted: Wed May 16, 2007 3:46 pm
Thanks Lou,
I'll have to check the head I'm working on because I was sure that when I blew out the holes they all went into the water jacket. I'm fairly sure that more than 2 of them did.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Wed May 16, 2007 4:44 pm
All the manifold studs go into the water jacket but some heads have so much rust build-up, they don't leak coolent out the hole when the stud is pulled. :shock:
On head torque, I always recheck the head's torque after the first heat cycle. I never use any sealer or thread locker. I do put some anti-seize compound on the bolt threads before installing the bolts.
PostPosted: Wed May 16, 2007 5:24 pm
Whew! I was afraid I might have a damaged head. The one for the motor I mean. :shock:
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
Users browsing this forum: Ahrefs [Bot] and 11 guests
